(1) 2 3 »
gx head
Quite a regular
From Townsville, Land Down Under
Guys,
excuse my ignorance but i did try a quick search with no luck.
My question is, how much would be a reasonable price for an a12gx head in good condition, and would it be a straight bolt on to a standard a12 (a12s if that makes a difference)block with no mods??
thanks for any info
Posted on: 2004/2/28 9:56
Re: gx head
From South East QLD
IF your going to use the STD single carby .. there wont be much gain ..
Posted on: 2004/2/28 11:04
Re: gx head
Quite a regular
oh, and also with factory twin su's
Posted on: 2004/2/28 11:15
Re: gx head
From Melbourne, Australia
yeah it'll bolt on, and will make a big diffrence in perfomance
Posted on: 2004/2/29 6:05
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: gx head
From Christchurch. NZ
On the intake manifold studs, do these accomidate both mounting systems of the A12 and the A15, or is that just the one I seen?
Posted on: 2004/2/29 10:19
Re: gx head
Quite a regular
from what ive seen on b120dat's gx head, it accomodates the a13/14/15 intake manifold bolting studs, but i could be wrong...
Posted on: 2004/2/29 10:43
Re: gx head
There are only two diferent stud patterns for mounting manifolds to "A" series cylinder heads.
All round port heads are the same as each other.
All oval port heads are the same as each other. That means that the A15 & 1200GX manifolds should be interchangeable.
Chris
Posted on: 2004/2/29 10:46
Love your Datsun.
Treat it well.
Re: gx head
Quite a regular
dodgeman.. that is not *entirely* right.
i have a standard round port a12 head, yet it still matches the manifold bolting of the a12gx/a15 head.
Posted on: 2004/2/29 11:33
Re: gx head
You got me there.
Is it possible that someone has drilled & tapped the cylinder head for the extra studs?
I ask because i have never known of this pattern on a round port head before, & i am assuming, rightly or wrongly, that the center stud [hole] is in this head above & between the "pairs" of round inlet ports, giving, in effect, a dual pattern.
I had also always believed that this stud pattern was created for the oval port head, to provide greater support & to ensure more even clamping force around the increased circumference of the oval ports.
Tell us more, as you have my undivided attention now. This has got to be a rare one. Do you have, or have you seen, the round port manifold that goes with it?
Posted on: 2004/2/29 11:53
Love your Datsun.
Treat it well.
Re: gx head
I thought all 1974-up engines use the "new" pattern, with 1973 and before using the "old" pattern (except GX (A12T engine)).
Posted on: 2004/2/29 11:58
(1) 2 3 »
