« 1 (2) 3 »
Re: gx head
Quite a regular
From Townsville, Land Down Under
i'll find out tomorrow if the head has, in fact, been drilled and tepped. The head i have is a G25 (checked yesterday), but, assuming it was a standard A12, i never took the manifold off.
But in any case im pretty sure it is a round port head, as the manifold itself looks to be round, not oval. hmm Weird .
Posted on: 2004/2/29 12:00
Re: gx head
Maybee that is right, but i haven't come across that as yet. Perhaps i'm still playing with stuff that is too old.
Posted on: 2004/2/29 12:01
Love your Datsun.
Treat it well.
Re: gx head
Quite a regular
dd,
unless australia was an exception, i dont think the a12 had the new pattern. If you look at b120dat's original engine, the manifold seems to be the old pattern. However being an 80 model, this is a *new* engine, if that makes sense
Posted on: 2004/2/29 12:03
Re: gx head
Thanks for clarifying that. You would know better than me ... USA didn't get any A12 after 1973.
Posted on: 2004/2/29 12:13
Re: gx head
From Melbourne, Australia
yeah im gonna back up dodgeman, i've found all oval port are new style, all round are old style, if i saw otherwise i'd be pretty sure it had been modified
Posted on: 2004/2/29 23:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: gx head
Quite a regular
I took off the manifold(s) and checked the head today. All you guys are correct, the ports are round and some other owner has drilled and tapped the head to fit the manifold.
The head has tapped holes where the normal a12 manifold was meant to bolt on .
Posted on: 2004/3/1 8:54
Re: gx head
From Christchurch. NZ
so the conclusion is, if there is enough "meat" on an a12 manifold, then it can be ported to match the oval port. and the A15 head can be drilled and tapped centre port to suit. yeah?
Posted on: 2004/3/2 6:57
Re: gx head
Quite a regular
actually dattodevil.. its quite the opposite (kinda). The thread was kind of confusing so i'll try explain it better.
When i had a look at my presumably A12 engine, i noticed that the intake manifold was the kind that fits on an A14/15. So naturally i got wondering as to whether my head was, in fact, larger than an A12.
However, upon closer inspection, i found that the head itself was a standard round port A12 head, which had been drilled and tapped to suit an A14 manifold. (why i dont know).
The moral of the story? I was wrong, everyone else was right .
Posted on: 2004/3/2 12:44
Re: gx head
well my delema is that I have an A12 sidedraught manifold, that I want to fit to an A15 head. now the ports aren't a problem because I can change that. I figure a solution to the mounting problem will be to drill and tap a hole, centre port, like the gx head that A14force has got. which is the original question I had. "are all GX heads set to take both manifolds, or just the one I've seen?"
Posted on: 2004/3/3 9:21
Re: gx head
From Freo
Just to throw stuff in the works, I've seen late model studpattern heads with round ports, with the little water jackets at the bottom, (like the oval ports have)
I've drilled and tapped later model heads to fit early stud pattern manifilds..
Posted on: 2004/3/4 14:13
« 1 (2) 3 »
