injectors
From Goulburn NSW
Hi guys when talking about injectors what does low impedance mean.
Posted on: 2011/11/20 6:55
Re: injectors
From Goulburn NSW
any advice would be appreciated.
Posted on: 2011/11/20 8:04
Re: injectors
Have you tried a google search?
Posted on: 2011/11/20 8:15
Re: injectors
Quite a regular
low impedance means the current needed from the ecu to open the injector is high(lower the impedance-higher the current)...(higher the impedance-lower the current).
impedance, flow rate and type of injector needs to be know to accurately determine which injector is needed.
by type of injector i meen whether or not they are (peak then hold) or normal.
some ecu's sre dependant on this type, motecs for example.
Posted on: 2011/11/20 11:45
