A14 Mild Cam ???
From Toowoomba
What are the specs for a good all round mild cam for an A14?
The engine has twin Hitachi carbs and extractors..
Posted on: 2011/11/20 7:47
Re: A14 Mild Cam ???
This is a good all-around mild cam for A14. You can lug it an 1500 RPM, and it will pull all they to 6000 RPM.
Exhaust open duration: 256 degrees
Intake open duration: 248 degrees
Intake opens at: 14 degrees BTDC
Intake closes at: 54 degrees ABDC
Exhaust opens at: 56 degrees BBDC
Exhaust closes at: 20 degrees ATDC
Posted on: 2011/11/20 7:58
From Toowoomba
Cool thx...
Next question..
Where can I get one???
Posted on: 2011/11/20 8:01
Quite a regular
send any camshaft company an email telling them your exact engine specs and what you plan to do with it and they with email you back a cam profile with a cost.
Posted on: 2011/11/20 11:40
You can get that cam from Nissan. It is the common A14 cam profile. A very flexible grind, mild, yet makes max power at 6000 RPM.
A custom cam company can make a similar version with a higher lift. That would be even better.
Posted on: 2011/11/21 4:39
