Rough Idle
From Brisbane
my car idles fine when its on park or neutral, but when I put it on drive or reverse its a little bit rough it like its going to stall, I had the carb (stock) tuned, i checked the timing the plugs were replaced last year, carb was re-kitted
Posted on: 2004/3/7 1:54
Re: Rough Idle
Quite a regular
From Townsville, Land Down Under
Sounds like it has a flat spot. I would replace the accelerator pump, and check to see if the power valve isnt loose, and is working properly.
Also, like i said on your other post, i would check or replace your fuel filter.
Cheers
Chris
Posted on: 2004/3/7 5:32
Re: Rough Idle
From Brisbane
will try to change the fuel filter tomorrow,
im getting 32/36 weber anyway just looking for the adapter plate
Posted on: 2004/3/7 8:14
