Quick fix for sloppy steering column bush.
From Perth WA AUS
I had a hell of a lot of play in my steering column due to a worn and crumbling bush, with a motorsport event coming up in a couple of weeks and no time to search for parts I had to think up another dodgy levey fix!
Here it is, nolothane steering bush made with a 32mm hole saw and a little bit of sanding to get a nice fit (nolothane from spare 120y LCA).
Should last for a while & zero play in the column now
jpg  Steering bush 001.jpg (69.72 KB)
9665_4ed1eaab817a1.jpg 980X735 px
jpg  Steering bush 002.jpg (137.72 KB)
9665_4ed1eabc0d460.jpg 980X735 px
Posted on: 2011/11/27 7:46
Datsun 1200 2Dr sedan.
Re: Quick fix for sloppy steering column bush.
Nice work dodgey.
But I thought you liked to play with shaft???
Posted on: 2011/11/27 7:53
From Ipswich, QLD
Thats a good idea, It'd be good if you could by sheets of nolathane and make your own bushes etc. Hmmm...
Posted on: 2011/11/27 8:06
From Perth WA AUS
I got sick of playing with the shaft Mik!
Nylon would probably be better for bushes but I only had nolothane :(
Posted on: 2011/11/27 8:13
And I bet you lubed it up real good too
Posted on: 2011/11/27 8:27
From Perth WA AUS
Yes I did, with silicon oil.
Posted on: 2011/11/27 9:40
