(1) 2 3 »
Geting hot
From Brisbane Qld
My B310 sunny has a old A14 in it and now its summer it runs it bit hot than i would like it to.
Can anybody tell what could i easly up grade my radatior to some thing biger from another datsun or another car all together?
Posted on: 2011/12/1 13:09
Re: Geting hot
Gemini ratiator... Check the tech wiki
Posted on: 2011/12/1 20:08
Re: Geting hot
From Armidale N.S.W
Or give ya cooling system a flush and get a new thermostat and radiator cap.
Posted on: 2011/12/1 21:31
73 1200 wagon SOLD
Re: Geting hot
Quite a regular
From northside brisbane
had same problem last month ,done what andy said made a huge change for the better .also used a good coolent
Posted on: 2011/12/1 21:46
when thowing rocks at seagulls never leave a tern unstoned.
Re: Geting hot
Gemini, corolla 4age model, n12 pulsar, s13 Silvia, many of options but a good flush by yourself or a radiator company, you may even need tank/core replacement! Or get a custom one made!
But as Andy and scottO said flush, new coolant, cap and thermostat may solve your problems and be the cheaper way to do it
Posted on: 2011/12/1 22:12
Car free
Re: Geting hot
From Brisbane Qld
Yes i gave it a flush cap is not that old i think will just get a biger radaitor.
I think the engine just fked it blow,s a lot of smoke and doesnt run that good at all. I think i have done all i can rebuilt the carbie. Checked all the leeds tested with a meater and cleaned points and plug,s my mechanic keep,s telling i should Rebuild a good egine.
Posted on: 2011/12/2 0:06
Re: Geting hot
To determine whether it needs a rebuild, give it a compression check.
Posted on: 2011/12/2 1:05
Re: Geting hot
From Brisbane Qld
Put some new plug,s in and guess what it runs ok now.
Till the next time it foul,s the plug,s agine.
I think its about time i rebuilt a egine
Posted on: 2011/12/2 7:32
Re: Geting hot
From Melbourne, Australia
foul with oil? or dry black stuff?
if its oil then head or rings are leaking, if its dry black stuff then it probably just needs a tune as its running rich
Posted on: 2011/12/2 7:36
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Geting hot
From Brisbane Qld
Every time i take them out thay have what looks like carbin on them not realy oil
My mechanic said the mixture is ok
Posted on: 2011/12/2 12:59
(1) 2 3 »
