« 1 (2) 3 4 5 »
Re: A15ETT - inspiration to do a rebuild/rebirth
From Melbourne, Australia
that was quad-turbo... only a joke... but two turbos were mounted (in that picture) and used... there is plenty of pics, i will be digging them up and bringing all to this thread
simon- it was/is running delco computer and sensors from a camira, programable with the right equipment, i think the new evolution will involve proper aftermarket ecu though
Posted on: 2011/12/3 5:26
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
some shots of the motor in final config
A15
factory injection manifold
delco computer and all sensors
throttle body from a camira
factory elec dizzy with camira module attached
two daihatsu charade 1ltr turbos, recently rebuilt for me not long before i stopped using this motor
dellow bell housing and celica 5 speed
intercooled and blow off valve
i actually had new dump pipes fabricated after that photo and 2.5in mandrel exhaust
here is the first mock fit of the turbo manifolds we made
Posted on: 2011/12/3 5:35
1200 Coupe Rallycar
the early days shots...
this was the very first setup... a lot of this was made by another guy clint who used to be a member, there was quite a few issues with this but mainly the exhaust manifold cracked very quickly and the throttle into the boxed carby constantly jammed
if the exhaust manifold was steam pipe and the throttle problem was solved.. this actually was a pretty cool setup - and using the stock carby!
Posted on: 2011/12/3 5:37
1200 Coupe Rallycar
this was the next major change... a weber 32/36 with the new exhaust manifolds i made and the carby boxed chopped down to just be a hat on top of the carby
Posted on: 2011/12/3 5:39
1200 Coupe Rallycar
after many gasket failures and fuel streaming out of the carby over hot turbos... it was decided there was only one solution
Posted on: 2011/12/3 5:40
1200 Coupe Rallycar
Posted on: 2011/12/3 5:43
1200 Coupe Rallycar
some lovely chap put an end to my coupe - hit me into another car when i was sitting at red light
RIP the red coupe
Posted on: 2011/12/3 5:45
1200 Coupe Rallycar
which is when the ute first came on the scene - used the insurance money to buy unfamilia's old ute, and quickly dumped the turbo motor in
Posted on: 2011/12/3 5:48
1200 Coupe Rallycar
ok so that exhausts the pics that were on datsun1200.com anyway..
my mind is starting to churn
im tempted by straight gas for the ease of the throttle body
and i also have a EFI hardware quad throttle body setup im not using....
Posted on: 2011/12/3 5:51
1200 Coupe Rallycar
I remember seeing the ute, minus interior and driveline sitting out front of your parents place a while back. Looking back it makes perfect sence that Mik was the previous owner.
So what now? What sort of boost was it running and how fast and far did it work through the range?
Posted on: 2011/12/3 5:57
« 1 (2) 3 4 5 »
