engine temp raising
Not too shy to talk
after driving for a while the engine temp starts to rise. it dosent get hot enough to blow the head but it still raises. it does this when the car is stationary, but as i drive the temp goes back to normal (about half)
is this normal or is there a problem??
cheers
Posted on: 2011/12/5 3:02
Re: engine temp raising
So temp increases when stoped or under 60kmh- get the rad cleaned, it's air flow related too through core. Do you use factory fan shrouded or elec thermo fan
Posted on: 2011/12/5 3:31
Not too shy to talk
nah it rises when im stopped. and i use the factory fan
Posted on: 2011/12/5 13:46
According to Owner's Manual: Water Temperature Gauge, this is the normal range:
Posted on: 2011/12/5 20:18
It's probably just airflow or partial blockage in rad. I've learnt how important shrouding is too.
How hot is it getting in traffic?
Posted on: 2011/12/5 21:50
Getting hotter at idle is not so common, is it? The ones I've seen get hotter at speed.
Sounds like not enough air is flowing at idle.
* If you have the wrong A12 fan, it may be too far away from the radiator (normal is about 1" (30 mm).
* Shrouding can be important depending on the radiator and core support (some have a gap and need the shroud, others don't need the shroud).
Posted on: 2011/12/5 23:00
Not too shy to talk
yea the engine temp is at the picture u uploaded, i was just worried that it was too high. thanx alot guys
Posted on: 2012/1/26 13:33
From Seattle ,WA.
in a newly rebuilt A15 engine with a new 3 core radiator running an electric fan & a re-cored heater core & new control valve my temp gauge is always at the middle of the gauge or slightly under it. Laser temp says its 178 - 180ish F water temp.
you can see the gauge a little.....
Likely its not just airflow, if any of the cooling system components are original or have a lot of age to them it can be all factors. Blocks, radiators, heater cores & valves clog & reduce flow - most likely candidate is the radiator water flow .
Getting hotter at idle should be more common as theres no airflow over the rad as well as less coolant circulation thru the motor.
Posted on: 2012/1/26 17:53
Yes, if you fit a larger/triple core the temp will be more steady.
But varying a little is normal and won't hurt the engine. I've had a 1200 since 1981 and never blown a head gasket. Temperature moves a bit in the normal range. Cools down at idle, raises a little on the highway. As long as it doesn't cross the H mark, it is OK.
I run A12, A14 and A15 with the stock 1200 radiator. No problems.
Getting hotter at idle is a fan problem. Electric fans often don't work as good as the stock engine-driven fan.
Posted on: 2012/1/26 23:46
Not too shy to talk
fanx guys :)
Posted on: 2012/2/5 1:21
