L series clutch question
well from my research there are only 2 cluth pressure plate heights, 41 or 51mm. Is this correct?
as im using the short throw out bearing carrier, i need the taller pressure plate, 51mm correct too?
also are there any samller clutch disk size than 200mm, i hope not. and i dont want to step up to the 225mm as my flywheel is already set for the smaller plate.
thanks.
Posted on: 2011/12/13 10:20
Re: L series clutch question
I'll go measure mine up mik, I've got 3 here from memory I even might be able to help with fly if needed
Posted on: 2011/12/13 10:22
Car free
oh also the bearing needs to be pushed onand off the carrier, is it just a simple puller to get it off or a specialist tool?
im planning to change it all with the help of another member after xmas.... stuff paying mechanic $350 in labour not including parts and stuff.....
nah stuff changing fly too.... thats a pita.
Posted on: 2011/12/13 10:23
Easy! Not hard mik! If box out and clutch off it's only 5/6 bolts to take off fly! Stress less
Posted on: 2011/12/13 10:24
Car free
There are three size of L-series clutch disk/pressure plate
180mm - L13 & L14
200mm - L16, some L18
225mm - L20B, some L18
Posted on: 2011/12/13 10:26
i doubt it would be the 180mm one... wish i or piggy could remember, i just remeber it was the smaller 1, as l13 and 14 arent sold in aus, im guessing its the 200mm one.
Posted on: 2011/12/13 10:29
I've got 3 200mm flys here mik, and the 4 speed I've got has bearing and carrier is bout 50mm
Posted on: 2011/12/13 10:39
Car free
3 200mm flys or 3 200mm clutch disks?
what tyoe of clutches? any good ones for fanging lol.
ill have to get thrust bearings too. cheers nik.
Posted on: 2011/12/13 10:43
ive got flys, pressure plate no good, and clutch plate almost stuffed to1
i have an almost new set here but its bolted to my l16 with the stumpy 30 hanging o0ff motor
Posted on: 2011/12/13 11:14
Car free
