CA18DET turbo oil feed help.
hi guys
I'm starting to work out what i need to make up the oil lines to the turbo.im running a garrett turbo which has two tags on it "GT3071R" and "GT2835-56T".What i was planning on doing was removing the standard oil feed block from the motor and getting a fitting from the block to -4 AN then run to the turbo inlet with braid.
What i cant find is a fitting to suit the thread in the engine block once i've removed the standard elbow. ive tried 1/8" NPT which is tappered thread, didnt work. Can someone advise me if its a metric or imperial thread? i was thinking 1/8 BSP or M10 x 1mm??
Another thing im not to sure about is that the original elbow has a restrictor in it. Because im removing that fitting do i still have to run a restrictor at the turbo inlet? turbo is ball bearing.
Last one is ive purchased a turbo inlet fitting which is a male inverted flare 7/16" -24 short. it threads well into the turbo inlet but seem to reach the seat in the turbo after just 2 - 2.5 turns. it seem to be sealing good but the fitting seems to stick out a fair bit? has anyone encounted this before? different fitting or leave it as is?
any advive is greatly appreciate guys
cheers
Rob
Posted on: 2011/12/28 14:15
Re: CA18DET turbo oil feed help.
From Brisbane
speed flow. pretty sure thats the one
1/8” BSPT -4. 381-04
could ask this guy, helped me out before with the ca lines
http://www.midnightmods.com.au/zen-ca ... &cPath=68&products_id=191
buying a kit some times works out better
Posted on: 2011/12/29 9:34
Edited by oda70 on 2011/12/30 7:27:16
1/8bsp to -??an what Eva size u want as long as banjo bolt is the right flow
Posted on: 2011/12/29 10:27
Car free
From Perth
The threads on the turbo will be metric
The thread off the oil pump outlet for feed is probably BSP... which I think is 28 threads per inch... and NPT is 27
Usually they pretty much interchange
The catalogues I have say the thread for the oil pressure switch on a CA18 in an EXA is 1/8 gas
You'd think Nissan would use metric threads... but not always the case
Though I have no CA experience so just going on L and A series info here
Posted on: 2011/12/29 12:22
