« 1 (2)
Re: Strut top Nut turning
The same thing as my shank nuts do, they fit perfectly in the bearing. The step is on the shock strut top and the spherical washer sits on that Holding top hat under it, will dig up some pics in an hour when on computer
Posted on: 2012/1/8 11:38
From North Coast NSW
awesome thanks heaps mate would love to see them :)
Posted on: 2012/1/8 11:51
in need of 1200 coupe parts!
well heres the step in strut i was talking about
heres what you need
get the right pitch and tread size and cheaper than getting the standard coil over top nuts to fit.
Toyota celica ones i think they were. $10 a set of 4 from supercheap.
as for the conical spacer washer???? i used some from some subaru struts i had lying around that fit. before that i used high tensile washers of vaious sizes stacked to get the right spacing to let the bearing move.
dodgey buy effective. i greased them slightly too to allow movement so the wheel nuts didnt loosen up if they spun.
the washer sits on that top step below the thread(in my picture the washer was too big and was forced down shock tube shaft (similar to how your struts came through bearing).
the spring top hat sits below that washer. if you had long shanked nuts, you could even possibly install thriust bearing and place washers on top to sit under the pillow ball but then there would be bugger all thread holding shock strut to the wheel nut.... easy to work out once its all apart.
Posted on: 2012/1/8 13:14
thanks heaps dude you have been a huge help :) really appreciate it. Cheers Nick
Posted on: 2012/1/8 14:34
I got two washers on the lathe machined them down a bit so the pillow bearing had enough movement put them it as it has solved the problem but now my cars looks like a 4x4 haha well compared to what it was with the stock tops. Is it just because its bolted further down in the towers? i know the shock comes up a lot more with the stock tops but id there any ways to get around this and make it lower?
Thanks heaps guys. Nick
jpg  2012-01-09 17.08.22.jpg (99.79 KB)
8461_4f0a909ef3b3a.jpg 640X480 px
jpg  2012-01-09 17.08.29.jpg (68.59 KB)
8461_4f0a90b20f711.jpg 480X640 px
jpg  2012-01-09 17.14.43.jpg (95.16 KB)
8461_4f0a90c210128.jpg 640X480 px
Posted on: 2012/1/9 7:06
Lowering springs or cut the coils off yours
That's one reason went coil overs
Posted on: 2012/1/9 8:11
Hahaha #OOPS# knew that someone would say that haha i've already got 3mm lower king spings but i think ill have to cut them. You should always cut coils from the top or bottom? Im sure its the top just wan to make sure ;) cheers
Posted on: 2012/1/9 9:05
It's illegal lol. I'd say bottom as there is that dip for the to seat in......not that I've ever done it
Posted on: 2012/1/9 13:43
hahaha im sure you have done it plenty of times :D Alright thanks again been very helpful :)
Posted on: 2012/1/9 13:54
« 1 (2)
