(1) 2 3 4 ... 6 »
Lowering Blocks & Handbrake Cable
From Sydney NSW
Do lowering blocks affect the rear section of the handbrake cable? The two rear handbrake cables i've tried seem to be too short on the double wire side (if that makes sense)!
I also have problems with the handbrake cable resting on the rear shocks? Any ideas?
Its in a 1200 ute
Thanks
Posted on: 2012/1/9 5:15
Re: Lowering Blocks & Handbrake Cable
From Melbourne, Australia
I just put lowering blocks in my ute yesterday and didn't have any dramas at all. I don't remember the handbrake cable being anywhere near the shocks to be honest.
Posted on: 2012/1/9 5:22
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
From Sydney NSW
Yeah i didnt think it should be a problem but handbrake cable definately looks to short and is hitting shocks for some reason :S
Posted on: 2012/1/9 6:08
Depends on which diff you have maybe someone has changed it b4 u owned it
Posted on: 2012/1/9 6:10
Car free
From Sydney NSW
thats a good point i'll upload some pics of where the handbrake and slave cylinder is
Posted on: 2012/1/9 6:51
1200 Ute
From Sydney NSW
compared to the wiki photo handbrake lever seems to be in a differnt spot?
jpg  1.JPG (120.03 KB)
12278_4f0a8f3c8a540.jpg 1037X692 px
jpg  5522.jpg (52.77 KB)
12278_4f0a8f5a0ef95.jpg 600X316 px
Posted on: 2012/1/9 6:58
From Castro Valley,CA USA
the pic with the two rear ends, the one with the leafs (rear) is an H145 from a 1200 sedan. The one with with coil spring perches is from a 210 (b310).
In any case, on a sedan, adding blocks under the axle doesn't upset the handbrake cable. It only blocks easy access to the bleed screw. Nothing major, it just makes it a pain to get a hose on it when you bleed the brakes.
Posted on: 2012/1/9 7:21
Have u adjusted the handbrake? I've had problems recent with h145/h165 handbrake cables are about 2" differant, try backing hand brake off at from of diff
Posted on: 2012/1/9 7:22
Car free
From Sydney NSW
The rear section isnt connected to the front handbrake section at all atm, so dont think thats whats causing it?
From the pick of my diff does the handbrake lever on the drum look too rotated towards the front of the car, if you get what im saying?
Posted on: 2012/1/9 7:36
1200 Ute
It almost look 180 out mines down near shock mount, I'll snap a pic if u pm an email I can send to
Posted on: 2012/1/9 7:46
Car free
(1) 2 3 4 ... 6 »
