Need to borrow a ute diff housing
From Brisbane, Queensland
As the title says I need to borrow a ute diff housing so I can set my pinion angle and weld the diff saddles on. Let me know what you drink and I'll fix you up for letting me borrow it. I will only need it for the weekend. Any help would be appreciated just PM me and I'll get straight back to you.
Posted on: 2012/1/16 5:58
Until Morale improves the beatings will continue
Re: Need to borrow a ute diff housing
I'm in melbourne, but if nobody else can come up with one, it'd probably cost about $100 each way with e-go or whatever it is called) if I pulled the centre and axles out to keep the weight down as much as possible.
Posted on: 2012/1/16 7:36
John McKenzie
