Steering problem
From Chipping norton sydney
Hi I have a datsun 1200 ute n have r31 coil overs in it I need the steering arm that gose onto the bottom off the strut I was wondering wat everyone uses for this conversion as the r31 steering arm the tie rod hole is to big for factory 1200 ute one any help would be gud Evan if anyone had the part I need cheers
Posted on: 2012/1/19 11:00
Re: Steering problem
Tuf110 just sold a set, think he had stanza ones re threaded to suit
Posted on: 2012/1/19 11:03
I'll have a look might MSG him
Posted on: 2012/1/19 11:09
Oh he had s13, should be very similar
Posted on: 2012/1/19 11:13
Dose any one have stanza steering arms heard they work
Posted on: 2012/1/19 11:15
R31 struts are the 2.0 inch size. So you need a steering arm for a 2" strut.
Get a B310 or A10 steering arm ... but beware, they will make your steering slower.
Will 1200 ball joints fit into the larger steering arm? If not, then you can fit W50 ball joints. Which will push your track out a bit and add some negative camber.
The best thing to do is modify a 1200 steering arm to take the larger strut
See Knuckle Arm
Posted on: 2012/1/19 11:23
Ddgonzal have u had this done n do u no any one that modifies them
Posted on: 2012/1/19 11:28
Just get stanza ones- no need to mod and doesn't affect steering adversely IMHO. Yes it slows it slightly but 1200 stock steering is to light for me.
If your ball joints don't work late model ute(1976 or later I think) or stanza one work well. The stanza give you slightly more neg camber too.
Posted on: 2012/1/19 11:36
Do u no anywhere i can get them from
Posted on: 2012/1/19 11:39
Ball joints- bursons etc. stanza stuff- wreckers or baz at datsports pretty good with some stuff like this.
Posted on: 2012/1/19 11:42
