60A throughout bearing carrier
From Gold Coast, Australia
a mate of mine needs the 60A series throwout bearing carrier, the longer one between 56A and 60A series. he is putting a 60A 5 speed in his car and found the throw out bearing carrier too short. oh yeah that happened too me 4 years ago ahha message him if you have one please 0410 491 257 Stacey
Posted on: 2012/1/20 4:40
Re: 60A throughout bearing carrier
56A and 60 use the same carriers. But there are two different carriers.
Which to use depends on which Flywheel you are fitting: A12 (thin) or A14/A15 (thick). If using the A12 flywheel, you can fit an engine plate OR use the shorter carrier.
The three factors:
1. Plate or no plate
2. Flywheel Thickness (28 vs 30 mm)
3. Release bearing Sleeve length (27 or 22.5)
Posted on: 2012/1/20 5:34
