From Sunshine Coast, QLD
For Sale
1971 Datsun 1200 Coupe, 1973 Mazda RX2 12a Twin Dizzy Engine with Mazda 121 5 Speed Gearbox, Nikki 4 Barrel Carb, RX4 Gearbox Tunnel and 1/2 Floor-pan, Extractors with 2 1/2in Zorst, H165 Ute diff with Bluebird Center, Stanza Girlock Disc Brake Front End, Drums Rear, Hydraulic Clutch, 180b Brake Booster, Battery in boot, Hidden Wiring, Mitsubishi Starion Turbo Bucket Seats, All Tac-Welds have been Mig-Stitch Welded for Strength, as well as 3mm Steel Bracing from rear of Front Wheel Arch to Front of Rear wheel arch, and Heaps More, body was strengthened for a 13b Turbo, fully engineered in NSW and DOT Approved in Qld, Blue Plated with Engineers Report
BAD POINTS Enamel Paint Fading, might need respraying soon!!! Rear wheel bearing or Buckled Axle Flange,Drivers Side Slight Noise, Easy Fix!!! Horn Relay needs wiring back up!!! No Heater or Fan (removed due to RX4 Gear Box Tunnel) Molded 1200 Carpet Doesn't Fit!!!
Probably some more stuff Ive forgotten I have a full Report on the Conversion which is 7 Pages Long and Details the Whole Conversion and Modifications done to comply with Qld and NSW Laws Currently Registered, Driving around and Legal but Will need to get your own RWC and REGO
I will take some photos and Get some1 to post them for me(directed at you DatsAndy lol)
Open to offers, but serious ones only, don't be a #OOPS#wit, cause you will get treated like one
Chasing $9-10,000.00
Cheers, Jason
Posted on: 2012/1/25 2:09
