« 1 (2)
Re: Grinding noise
From Wellington
Ok I have square blocks
Posted on: 2012/1/26 2:27
Re: Grinding noise
From Wellington
Ok, just put the back up on ranps. I dont think it the drive shaft on the exhaust but I noticed oil above the diff.....it my diff on the way out???
Posted on: 2012/1/26 5:04
Re: Grinding noise
Doubtful that it's "on its way out". It is common for the front seal to leak a little after 40 years and to throw bits of gear lube up on the body.
Just keep following the recommended service schedule as per your owner's manual and check/fill the diff every year or whatever it says.
Posted on: 2012/1/26 5:10
« 1 (2)
