« 1 (2)
Re: Wtb a series 5 speed
Oh, didnt realise - thanks for that, better see if I can find a 60 series one lying around, to might it easier for prospective buyers.
Posted on: 2012/1/31 5:23
Quite a regular
"Standard shift pattern"... Does that mean it is an overdrive box ?
I have a dog leg 5 speed ( 1st is back and left )
Are they the same box ?
Cheers
Posted on: 2012/1/31 14:09
I was under the impression that 60A and 60L were some ratios.
but someone on here will know for sure.
spinning shaft it felt like 1:1 5th, but probably need to mark splines and spin a few times, cause if its over driven will only be like 1.03 or something?
Posted on: 2012/1/31 18:08
They are different boxes. 60L is a dogleg, 60A is straight pattern.
Both are overdrive. Gear ratios are slightly different but nearly the same.
See 5-speed Overview
Posted on: 2012/1/31 21:21
Edited by ddgonzal on 2012/1/31 21:47:09
« 1 (2)
