(1) 2 3 »
Ceramic coating Extractors Any one done this??
From Tasmania
Ive got to try and reduce the amount of heat I have in my engine bay. Due to the extractors and carbs both facing the firewall. I was thinking of getting the coating done to try and help with this.
Has any on on here done this before? any good storys or bad storys about it?
Posted on: 2012/2/7 10:53
Proud member of " The Tasmanian Datsun Owners Group"
Re: Ceramic coating Extractors Any one done this??
From sydney.nsw
troy; get them coated, then wrap them with exhaust wrap . works well.cheers
Posted on: 2012/2/7 11:08
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Not too shy to talk
From Tassie
I've heard that it's comparable to and it has or does about the same amount in heat reducing
effects/properties as the wrapping/lagging stuff you can get but is way more expensive if you have it done properly, ie: have it sent away and coated by a pro. I'm into the same idea also as it makes a lot of general sense to reduce heat in a car. Would love to go the coating though, looks ace.
Mat
TAS
Posted on: 2012/2/7 11:11
From Tasmania
Ive been given 3 qoutes One from Thermal Edge Coating in Qld. HP Coatings in Vic and Jet Hot in Vic as well any one used any of these brands??
Bige what coating did you go with?? before the wrapping??
Posted on: 2012/2/7 11:22
From sydney.nsw
ive use a number of people, its all about the prep before coating. how much have you been quoted.
Posted on: 2012/2/7 11:33
From Tasmania
$240, $270 and $225 plus fright etc.
Posted on: 2012/2/7 11:34
From sydney.nsw
thats cheap, the last quote i got was $420-$450.00( 1 month ago), that included, they prep them & coat them, i dropped them there and i pick them up.wrap not included.mob in blacktown nsw.also depends on quality of ceramic too. i guess.as they said.
Posted on: 2012/2/7 11:42
From Tasmania
Thermal Edge is there Satin Black product. HP is there HP2 black coating and Jet Hot is there Sterling coating.
Posted on: 2012/2/7 11:44
From Tasmania
Posted on: 2012/2/7 11:59
From sydney.nsw
try these people, ive havent used them yet,or called them,you can do that. hi octane performance coating. rydalmere nsw. web;www.performancecoatings.com.au get a price ,let us know.cheers
Posted on: 2012/2/7 12:07
(1) 2 3 »
