Good 5 stud diff for ca?
I'm looking into going 5 stud Nissan/ ford stud patten and need a diff to put up with a ca as a track built setup! No I want to stay with leafs! No 4 link ect just want to start with something that is LSD or easy to get 1.5 way for! And I don't really want to shorten it but I will be running flares and pumped guards so I could go I guess 4 Inches wider in total!
Looking for some info or ideas on good setups
Ta nick
Posted on: 2012/2/22 11:15
Car free
Re: Good 5 stud diff for ca?
Ford ute, they had LSD leaf rear ends
Posted on: 2012/2/22 12:00
From Sydney
Build a 9 inch then u get the exact setup you want. May cost more up front but at least it's exactly how u want it and your not going to want to change #OOPS# after your first track day
Posted on: 2012/2/22 12:05
Thinking a 9 might be to big! Only looking at bout 200rwkw and don't really want to spend big $$ as this was ment to be a budget build
Posted on: 2012/2/22 12:31
Car free
A borg warner is cheap and easy and there are heap of ratio's from 2.77:1 up to 4.11:1, as the right stud pattern and the EB on brakes clear 14 inch wheels. I have an ed 3.27 with axles and caliper brackets here if you're interested. Trade off on some parts of yours I want.
Posted on: 2012/2/22 19:55
Do it nick!!! Is it LSD don
Posted on: 2012/2/22 21:16
