Browsing this Thread:
1 Anonymous Users
Alternator woes |
Quite a regular
Our little Datsun Sunny has a Lucas alternator 15AC. The front bearing became loose in the housing. Having a few spare alternators about I used one of these as a basis for preparing a replacement. The slip rings are all new and all external features/connections are the same.
On fitting we now find that the engine won't shut off. I need to either disconnect the coil or pull the cable from the IND terminal on the alternator. This is the way it has been wired up. There are only the two connections.There is a third terminal marked Aux+ but not used.
Iam thinking there is a need for a relay but why would that be when outwardly both the old and the replacement appear to have the same configuration.
Any one with any clues?
Posted on: 2012/2/24 11:52
