What trans and differential conversion best on a 1200 A12a AT?
Not too shy to talk
From Garden Grove, Ca. USA
Hi,
My name is Roger. We live in Southen Ca. near Disneyland. Have owned a '72 Datsun 1200 fro 22 years. Just installed a remanufactuerd A12a. RPM's too high on freeways. Want to put a 5 speed with appropriate rear end. Any suggestions ? Only one experienced Datsun mechanic in all of Orange County, but he doesn't want to touch it. Otherwise car in great shape. Thanks
Posted on: 2004/3/18 16:42
Re: What trans and differential conversion best on a 1200 A12a AT?
Hi Roger, the Datsun 1200 differential is 3.9:1. Some B-210s had a 3.7:1 which would help. But with an automatic, it would reduce the get-up-and-go at lower speeds.
The 5-speed is a great option. Get one from a 79-82 Datsun 210 (chassis B310). 1st gear is not so steep, and the overdrive 5th is much more comfortable on the freeway.
These Tech Section articles will give you a start:
What Diff and LSD should I use?
5-speed Overview
Also see Manual to Auto conversion - how to?
Posted on: 2004/3/18 17:11
Not too shy to talk
Hi Again,
Just sent another e-mail with the same ? Sorry I couldn't find your first reply which we just read leading to another question if you don't mind. You suggested sapping our 3.9.1 differential with a 3.7.1. How is it identified ? Is it on all B210 5 speeds? Do differentials have such numbers on their shell or what ? Roger
Posted on: 2004/3/19 16:57
Hi Roger, "Datsun B-210" is 1974-1978, but "Datsun 210" is 1979-1982. Why did Nissan North America make this so confusing? I don't know ...
That being said, either a B-210 or 210 5-speed will work. I prefer the newer 5-speed as it has a standard shift pattern. The older one has a first-above-reverse shift.
Anyways, the 3.7 differential only was in certain B-210 or 210 models. Many of them came with 3.9 or 3.889. Here's the breakdown:
1974 B-210: 3.90
1975-1979 4sp and auto: 3.89
1975-1979 5sp 3.70
Or what, unfortunately. You can block one wheel, turn the center shaft 10 times and measure how many times the free wheel turns.
Posted on: 2004/3/20 17:56
