Rear coil overs and leafs
From Narellan,Sydney
Any one else run coilovers on the rear as well as the leaf springs to stiffen it
up?or would this make it to stiff? Thanks
Posted on: 2012/3/4 9:01
Re: Rear coil overs and leafs
It's in a 1200sedan with a 13b turbo street car
Posted on: 2012/3/4 10:08
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Melbourne, Australia
you would certainly take some of the leafs out, but could run the main leaf as a locator essentially, bigger problem may be the strength of the mounting points
in coupes i have seen shocker mounting pins bent regularily (h190 vanette ones are super strong though) but also the top of the shock ripping through the floor, if using these mounting points for shock absorber and spring thet would need some serious beefing up!
Posted on: 2012/3/4 10:40
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Yea well it is mini tubbed so was gunna run coil over straight thru the floor and weld a bar between the 2 tubs.you Reackon the leafs be strong enough with just the main Leaf in to keep diff located?
Posted on: 2012/3/4 11:00
why not 4 link it if your going to the effort of all this.... its half way there once you coil over the leaves, so it seems silly not to do it properly.
Posted on: 2012/3/4 11:03
probably with 2 leaves minimum, but if you go too stiff going to loose traction and axle tramp, probably rip a rear hanger straight off with serious power.
Posted on: 2012/3/4 11:11
I would like to delete the leafs but not really sure how to 4link a solid diff.sounds like a good idea if you can shed sum light on how to go about it?
i havent done it, shoota77 looking at if, a few members have done it. wards best to ask i think
Posted on: 2012/3/4 11:21
Thanks I'll try get Onto him
Posted on: 2012/3/4 11:22
From Perth WA AUS
Estyre has done it aswell, not sure how it handles but he might put some pics up for you.
Posted on: 2012/3/4 12:29
Datsun 1200 2Dr sedan.
