Electrical troubleshooting - Park and head lamps fuses become hot
Hello, i have an 1973 datsun 1200 sedan and having some trouble with my fuse block. Once i turn on my light switch on (tail and head) those 2 fuses start to get real hot(ranging 80-100 F). Also the fuel and temp gauge start to increase. I've checked all my 12volt source/grounds and cleaned them through out the entire car. All the wiring to the lights are fine. I even bumped the amps from by 5 for each fuse, 20amps-head and 15amps-tail, which seem to help out a little by not getting as hot. My charging system is good as well. However i do have multiple stuff unplugged like my entire heater system, seat indicators, dome light, and cigar lighter. I need HELP! its driving me crazy. Could it be my light switch? how do i remove it?
Posted on: 2012/3/25 7:12
Re: Electrical troubleshooting - Park and head lamps fuses become hot
From Sydney.au
if you are using non standard head lights (eg above 55watt) then that could explain it. when i upgraded my headlights to 100watt, i melted my fuse block!
Posted on: 2012/3/25 9:27
From Perth WA AUS
Did you clean the contacts in the fuse box aswell?
Posted on: 2012/3/25 12:13
Datsun 1200 2Dr sedan.
From Melbourne, Australia
If cleaning fuse box contacts dosnt work then best to put in a relay and just use the standard wiring as a trigger only, the old wiring is not in good condition anymore
Posted on: 2012/3/25 13:22
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
