Need help a14 block with locating stud/pipe on deck. help ASAP
as the title says. I have both an a14 and a12 block, im building a worked a12 block and it has been completely stripped of studs heater pipes etc.
What im wondering is the small locating pipes on the deck of the block which i believe locate the head and gasket. It also stops the head from moving?
Question is do i need these on my late model a12 block or not?
cheers
jpg  2538 with red circles.jpg (98.08 KB)
13572_4f9165937402a.jpg 640X480 px
Posted on: 2012/4/20 14:38
Re: Need help a14 block with locating stud/pipe on deck. help ASAP
From sydney.nsw
i would say "yes". you need them to locate gasket & head properly.they put them there for a reason,most engines have some form of locating dowels. cheers
Posted on: 2012/4/20 15:23
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Yes you need them.
Posted on: 2012/4/20 22:00
ok thanks guys, i was thinking i should have them also, but i was confused by having to early model a12 blocks that had none :S not a worry down to the shops this morning i go haha.
cheers
Posted on: 2012/4/20 22:47
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
