A14 missing and back firing
So my a14 was just put in my ute it has a big cam extractors 32/36 and exhaust and was running fine for the last few days and yesterday on the way out of work it started missing when taking off then just made a massive bang noise I took spark plugs out and cleaned and got it started but sounded like it didn't have all it's normal power and was missing what could this be ? It has a new coil,alternator ,fuel pump
Posted on: 2012/4/25 2:01
Re: A14 missing and back firing
Could be a cracked piston. Did you have the valve-to-piston clearance checked?
I would give it a compression check.
Posted on: 2012/4/25 3:58
From sydney.nsw
were you giving it a hard run when it went bang.
Posted on: 2012/4/25 7:03
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Nah just cruising up the street
Posted on: 2012/4/25 10:12
datsun a15 ute
From sydney.nsw
so is just missing now or does it have internal engine noises(like metal type knocking or what)
Posted on: 2012/4/25 11:26
Nah it's just missing doesn't want to run doesn't sound like internal
Posted on: 2012/4/25 21:21
datsun a15 ute
Take the rocker cover off and check for a bent pushrod. Or more. It will also give you a chance to see if the camshaft is turning.
With a problem like that of what you are describing, it it a bit open ended. Too many things that may have gone wrong.
Posted on: 2012/4/25 22:14
