« 1 ... 23 24 25 (26) 27 28 29 ... 52 »
Re: EVO 8 powered 1200 Ute
From SA
its off a Mitsubishi starion mate to run a 55mm strut, Had the starion lower control arm on but it was to long and gave way to much neg camber...
Posted on: 2012/4/22 10:08
Do the starion ones bolt straight up to the 1200 x member?
Posted on: 2012/4/22 11:02
From SA
There is a little slop with the Bush But with some new (longer ) Bushes they will fit fine, Just to long really !! They are standard datsun Lower control arms in my pictures, Welded and re drilled to fit the Starion gear. They are not starion lower control arms...
Posted on: 2012/4/22 12:27
From Melbourne, Australia
hey smurf, see the starion on carsales for $500, blown clutch s all thats wrong with it
i was tempted, you might know someone or needs bits from it
saw it a few days ago, so may be sold by now
Posted on: 2012/4/22 15:24
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From SA
No #OOPS# !!! Thats pretty cheap.. hahahaha
Posted on: 2012/4/23 11:11
From SA
Posted on: 2012/4/26 7:43
Edited by SmUrF_11 on 2012/12/19 2:58:36
That's so cute, I want one! Are you going to box in the filter!
Posted on: 2012/4/26 7:54
Car free
There's more metal there than in a stock front end
Posted on: 2012/4/26 8:09
From SA
SupA - hahahah isnt it !!!! If you go back to page 14 i think it is, My air Box pictures are there
UnFaMillA - When i went over the car before i started stripping it with the engineer. He stressed if you started cutting panels You need to some how replace them we equal Stenght... hhahhaha so in my head that means Metal, Metal, Metal.. I am not worried about weight !
Posted on: 2012/4/26 8:29
From SA
Posted on: 2012/4/30 8:25
Edited by SmUrF_11 on 2012/12/19 2:58:58
