Front control arms and rods
From Narellan,Sydney
Wondering what front control arms and all rods I need for the stanza struts in my 1200 sedan.and no maddats rebuild kit is no good as I rang them today and was told they are struggling to source the parts to make the kit.after these asap
Posted on: 2012/5/1 10:51
Re: Front control arms and rods
Stanza lca bushes are same size as 1200 ones do use late ute or stanza ones.
Posted on: 2012/5/1 11:05
From Armidale N.S.W
Click Link. I assume it is the info your after.
http://datsun1200.com/modules/newbb/v ... =ASC&type=&mode=0&start=0
Posted on: 2012/5/1 11:12
73 1200 wagon SOLD
Thanks that helps.any1 know where I can go to buy these arms and rods?
Posted on: 2012/5/1 11:28
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Ozdat or eBay or call datsport
Posted on: 2012/5/1 11:33
You have earlie stanza stuff
Posted on: 2012/5/1 11:53
Car free
What controls arms and steering rods does that mean I need nick? Sorry should of msged you about this 1st
Posted on: 2012/5/1 12:28
Prob need late ute or 120y etc... It's the ball joint and steering arm that's different too.
Posted on: 2012/5/1 12:44
All good bud, that's what this site and others here are to help, as I said easy way to tell is 8mm bolts in lca's are late ute/stanza and castor rod has a scollop between bolt hole to allow larger ball joint
Posted on: 2012/5/1 13:24
Car free
wiki link for steering arms
read away- pics and info
Posted on: 2012/5/2 10:58
