« 1 ... 10 11 12 (13) 14 15 »
Re: Rob's CA18DET 1200 UTE.
From SA
She def is hanging down low, what's your min hight in your state ?? SA is 100mm from lowest point of the car which normally is exhaust...
Posted on: 2012/5/9 2:58
From SA
Bro you wouldn't be able to measure from your strut tower to the outer edge of your break booster/set up.. Trying to work out if a maddat set up will clear my intake manifold,
Thanks buddy
Smurfos
Posted on: 2012/5/9 3:07
hey smurf,
yeah its the same here 100mm, atm its 75mm with the cut out installed, gonna have to work something out.
ive got this photo with measurements if it helps? measured with a tape so their with in 5mm ish
Posted on: 2012/5/9 5:02
From SA
Rob !!! You have out done yourself mate, that do helpful !! One other question
With your rear coilovers... From ride to full bump and ride hight to full droop how much travel have you got??? What sting rates did ya go for ??
Posted on: 2012/5/9 9:22
Hey mate
Not sure if this is what your after Ride to bump is about 50mm ish pretty sure I got the 180 pound I'll have to check.
Posted on: 2012/5/9 9:39
From SA
Yeah no worries mate, I have pretty similar travel from what I have worked out so far !!! Taking it off the spit this weekend to work out ride hight properly !! cant wait
Posted on: 2012/5/9 11:53
bit of an update, scrapped the exhaust that i'd already started notched the gearbox cross member and gained about 35mm extra ground clearance then i originally had. Made up a removeable tailshaft loop and tac'd it in, also got the infill panels done around the cooler. hopefully not long now till i can strip it down complete all the welding n start the preping for paint.
Posted on: 2012/5/20 12:40
nice love seeing these updates
Posted on: 2012/5/20 13:15
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
made a bit of progress the last couple of nights,started again with the exhaust got about 110mm ground clearance.
Posted on: 2012/6/16 14:02
From Goulburn NSW
Hi rob when u tubbed it did u tubb it to the rails.
Posted on: 2012/6/24 10:09
