Sunny Van disc brakes
Gday peoples,
Does any body know if you can do a straight bolt on conversion from 1200 ute drum fronts to Sunny front discs and booster/pedal assy? I have a parts donor Sunny van that has discs on the front and drums on the rear,I figured that I would be able to change the discs and booster/pedal assy over but wondered if the backing plates and caliper mounts will bolt onto the drum mounting points?
Any advice/hints greatly read. Cheers Nosaj
Posted on: 2012/5/19 7:35
Re: Sunny Van disc brakes
No they will not. Calipers will not bolt onto a drum-brake strut.
If your van came with 12" wheels, you can fit the entire B310 strut with brake assembly. But you need to lower the spring cup.
Posted on: 2012/5/19 8:20
