« 1 (2)
Re: maddat coilover ride height
From Melbourne, Australia
It's probably at the perfect height in terms of handling and not causing any issues with scrubbing guards and firewall but it's not super low that's for sure.
That highlights the benefit of doing it yourself so you can weld on the coilover section as low as you like!
My minimum height is limited by the offset of my wheels. I can only wind the lower perch down to a certain height before the perch gets too close to my tyre/rim. It can go a lot lower than your pic though.
Posted on: 2012/5/24 23:42
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
A lil disappointing when you think of the money that you spent to buy them you think that they would be able to be slammed way lower
Posted on: 2012/5/25 12:57
From Adelaide
If you want to give as a call with your concerns, we are more that happy to help out as much as possible. The hight you have in the front is as low as i would ever run my 1200's, any lower your handling will go to #OOPS#. We have built some quick race cars and found that your times will get slower the lower you go. Also you mustn't have much suspention travel on the rear with it that low.
Saying that we can make them as low as you want, but you will loose travel, handling and the springs will be not to near captive, thus macking your car defectible.
0411 133 955
Cheers Scott
Posted on: 2012/5/26 0:48
If life were easy it'd be boring
maddat.com.au
1200 ute SR20DET (Sold)
200BSSS (racecar project)
P410 Bluebird (original)
Merc. Vito Van (tow Car)
Thanks for that Scott awsome info looks like I'll just have stop Conplaining lol
Posted on: 2012/5/26 8:33
Just a stupid question is the bolt at the top of the strut is the to adjust the damper?? :-S
Posted on: 2012/5/26 12:02
« 1 (2)
