can you re-drill steel wheels to change stud pattern?
From Sydney NSW
There's plenty of cheap steel wheels with good offsets but in the wrong stud pattern, is it possible redrill them? I assume they come blank from the factory and are drilled after being pressed, so could maybe be drilled again.
not sure if they have a flat face where they mount to the hub like alloys or are located otherwise.
Posted on: 2012/6/10 16:05
Re: can you re-drill steel wheels to change stud pattern?
As a rule. No. The wheel pattern is pressed into the rim as you will notice behind the wheel stud hole. Redrilling steel standard rims is a dangerous idea.
Posted on: 2012/6/11 0:37
2nd that
Posted on: 2012/6/11 0:51
Car free
From Sydney NSW
ahh damn. i found some pretty interesting stuff about cutting off the barrel and welding in a new inner. anyone do that sort of thing in australia?
http://retrorides.proboards.com/index ... ction=print&thread=123002
Posted on: 2012/6/11 0:55
I would say a decent machine shop could definitely do that Finn.
A few people get their stockies widened (banding)- but it isn't the cheapest job.
Posted on: 2012/6/11 1:00
are the black wheels in the photo sorta what your after? you can buy them here in aus in dato stud pattern
Posted on: 2012/6/11 1:12
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Sydney NSW
sweet. yeah it looks like you can reverse them easy enough (at home even)
Posted on: 2012/6/11 1:15
There's a place in Melbourne that make custom wheels or try gecko
Posted on: 2012/6/11 1:24
Car free
Posted on: 2012/6/11 2:09
Where's the link dd, that's just google home page
Posted on: 2012/6/11 2:14
