putting doors back together
From Goulburn NSW
Hi guys i pulled the door trim of my ute today to have a look at the internal to see whether i will give it a go at swapping them.My ? is does the window go in first and how does the 1/4 window frame connect to the door at the top.I see where it connects at the bottom.
Posted on: 2012/6/13 8:32
Re: putting doors back together
Yes as I recall. Put the large glass in and hold it to the side while you manouver the 1/4 frame in.
Two small screws on the sloping part of the door frame.
Posted on: 2012/6/13 8:43
Glass
Removal & Reinstall
To reinstall, do everything in reverse. However don't tighten the screws on the quarter window assembly until you get the new window to align with the slots on each side. That is the hardest part.
1. Take apart the door bits and pieces
* Unscrew the door pull/armrest, door handle, and window winder
* Carefully pop the door card (panel) off to access the inside of the door. Use a putty knife or other flat tool, slide it between the card and door until you locate the clip. Then twist to pop the clip out. There are two on one end and three on the other end.
2. Roll the window up first. Then unbolt the window stop at the bottom of the door.
3. Roll the window down so that the regulator comes out of the track on the window glass frame but be careful not to let the window drop too hard. Leave the glass at the bottom of the door temporarily.
4. Take the quarter window frame out.
* There are three screws at the top of the door concealed under the door rubber.
* Also there is one larger screw towards the bottom of the door. It's recessed a bit.
* Once loose pull the quarter window assembly out.
5. Reach in the door and turn the door glass 90 degrees then pull of out from the top.
Posted on: 2012/6/13 8:47
From Goulburn NSW
Thanks dd ill give a go see how i end up,so th next ? is how do i get the bailey channel rubber glued in position iff im moving the frame to the side to get the big window in position.
Posted on: 2012/6/13 8:51
Move the glass into the rear part of the door frame, don't move the frame.
The other part the glass frame is the quarter window assembly. The has to be moved into place.
Cut the bailey stripping at a 45 so when the quarter window ASSY is inserted it will match up to the baily stripping in the top of the door frame.
Posted on: 2012/6/13 9:05
Maybe this pic will be better than my fumbling word explanation
The bailey channel rubber is cut into two pieces in a factory install. Run "A" piece is notched so it will fold at a 90 angle and a 45 is put at the end. Run "B" is angle-cut at the top so it will match up with Run "A" rubber.
Posted on: 2012/6/13 9:26
From Goulburn NSW
Thanks dd that expains perfectly what i was stuck on.
Posted on: 2012/6/13 9:28
From Goulburn NSW
Hi guys whats the best glue to us to glue the bailey channel rubbers in and also the door seals.
Posted on: 2012/6/14 9:32
From Narellan,Sydney
Any strong adhesive (super glue) I didn't even need to glue mine was a tight fit
Posted on: 2012/6/15 11:01
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Goulburn NSW
Hi guys will something like super glue eat into the rubbers.
Posted on: 2012/6/16 10:02
