(1) 2 3 »
throttle cable end?
hi looking to find something like this pic ture below.
basically need to mod a longer throllte cable for my new intake manifold.
rc provided two cables from his stash- just need to get the right kind of connection on the end - same as stock a series one.
its been sugested to use solder but i think its too soft and will wear through eventually leaving me stranded.
i thought of something similar to this as i found a bolt and a was going to drill a hole through it for the cable. was going to get it brazed onto the end so cable wont move.
any sugestions or ideas that might help? dont really want to pay for a new cable again..... $70 odd.
apparently lawn mowers etc use these kind of things. worth a shot or not reliable enough?
jpg  images_nipple20small.jpg (8.42 KB)
277_4fd87a492734c.jpg 150X100 px
Posted on: 2012/6/13 12:33
Re: throttle cable end?
From Perth WA AUS
I'll go and check my limited stash, back soon.
Posted on: 2012/6/13 12:36
Datsun 1200 2Dr sedan.
From Perth WA AUS
This is the best I can do:
jpg  thingy.JPG (124.49 KB)
9665_4fd8802c28425.jpg 980X735 px
Posted on: 2012/6/13 12:57
How well do they work Nigel? You only got one spare yeah.
Posted on: 2012/6/13 13:09
I think its the same thing but i have one of these on my single sidedraft weber atm. Im just using the standard a series cable in my ute, the cable connects to this, so far ive had no issues, however i have just moved the return spring to a better position which as also made it a slightly firmer pull back. See how we go and ill let you know!
Posted on: 2012/6/13 13:59
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From Cheltenham
What you have put up in the picture is a safty end for emergency power cut offs in race cars, im sure if you had a look around at the likes of Meridian Motorsport and Revolution Race Gear or something like that near your place im sure you would be able to find something
We used them on the formula fords as throttle cable ends as well as the cable stops for the power switches
Posted on: 2012/6/14 8:09
Split sinker and braise
Posted on: 2012/6/14 8:42
Car free
From Perth WA AUS
Pretty sure I have two of them Mik.
Posted on: 2012/6/14 10:24
Will see if I can find some here.
Posted on: 2012/6/14 13:57
From Perth WA AUS
Totally snubbed, but I can handle that :)
Posted on: 2012/6/15 15:11
(1) 2 3 »
