Early or late a12?
Just wondering which a12 this is, the distributor is behind the engine mount, alternator is on the left.
Posted on: 2012/6/18 13:19
Re: Early or late a12?
From Melbourne, Australia
late
early has front dizzie and alt under exhaust
Posted on: 2012/6/18 13:26
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
ahhh, so if i buy a buy an early block, it wont bolt up?
Posted on: 2012/6/18 13:30
From Brisbane Qld
yes it will u just have to use the right engine mounts
Posted on: 2012/6/18 14:27
From Trinidad and tobago
Use engine mounts for early a12 on early 1200 crossmember.
Posted on: 2012/6/18 17:07
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
You can bolt new A12 into old 1200 or old A12 into newer vehicle with slight fabrication. See A-series Engine Swaps.
Posted on: 2012/6/18 20:01
Dead set man go late, there is more bits around. I blew my early a12 up and starting building a late model a12 started with block and everything was different. I would highly recommend starting with a long motor!!
Posted on: 2012/6/18 23:48
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
