Big brakes hitting castor bars
From Narellan,Sydney
I have stanza struts with ford ba brakes but the calipers hit the castor bars.it properly has another 1.5-2" of more turning untill it's at full lock.any1 had this problem
Posted on: 2012/6/20 3:45
Re: Big brakes hitting castor bars
You could swap the struts left to right so the calipers are mounted to the rear.
Posted on: 2012/6/20 4:13
Sounds line u need bump steer spacers
Posted on: 2012/6/20 4:46
Car free
Try swapping strut sides usually have to with stanza I found
Posted on: 2012/6/20 5:58
Nah if I swap sides the steering arms hit the brakes.nick where can I find these?
Posted on: 2012/6/20 8:12
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Sydney
Maddat.
Posted on: 2012/6/20 9:32
Product No - BSS1600
Bump Steer Spacers (New Design)
Reduce the bump steer on your lowered Datto with the fitment of these 25mm spacers. Fits between bottom of strut & steering knuckle, hi tensile bolts & washers supplied. Suits struts with 80mm bolt spacing. $118
Posted on: 2012/6/20 9:43
Car free
http://www.maddat.com.au/200b.php
Sounds like your lower control arm when car is lowered runs out of the normal travel range
Car free
