« 1 (2)
Re: rear brake light stays on?
brake pedal sticks the slightest bit ... and it affects the engine idle
Vacuum Leak in the brake booster or the vacuum hose to the booster or the check valve in the hose.
Posted on: 2012/7/11 3:55
Thanks DD. I've replaced the check valve thinking the same thing but I think its a defected brake booster. It must have a little leak which causes it to lose vacuum. :(
Posted on: 2012/7/11 7:08
« 1 (2)
