? about oval port heads
From Goulburn NSW
Hi guys i have a question about the manifold for oval port head,can u run the standard carby or do u have to run twins.
Posted on: 2012/7/11 11:24
Re: ? about oval port heads
From Melbourne, Australia
Whatever you like.
Oval port heads were still standard with single carbs in a lot of cases.
To get full value out of them a 32/36 weber or set of twins will work well.
Posted on: 2012/7/11 11:26
Edited by Shoota_77 on 2012/7/11 11:45:07
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
by Shoota_77 on 2012/7/11 21:26:06 Whatever you like. To get full value out of them twins will work well on those ovral haeds.
Posted on: 2012/7/11 11:32
From Goulburn NSW
Where can u get webers from and are the expensive.
Posted on: 2012/7/11 11:41
32/36 are of xf falcons and the like. cheap at wreckers and usually in ok condition still.
idealy you need to rejet them to suit but i can one on an a15, ran a little rich but went well compared to twin su's even.
the adaptor available through lynx i think still.
Posted on: 2012/7/11 11:51
you can buy all types of webers from ebay, and yes theyre quite expensive but worth it i reckon, sound mad, more power, and i believe you get the "feeling" in a weber though the throttle etc., more than you will ever get with anything else... My opinion.
A twin sidedraft manifold new might be $250, and a pair of webers might be found from 600 to 1500... 600 needing to be rebuilt of coarse.
Dont forget if you are to get a weber or two, if its not new then generally it will need to have acarby kit put through it/freshen up. Or if its off of another car or larger/smaller engine, all of the jetting/ choking and other bits need to be done!!
Plus a dyno tune aswell which might put you out aorund the 500 mark, (from memory from what people told me, my local mechanic i have my maching work done doesnt get change from 600 when he gets his single downdraught tuned on his rotary....)
But the weber sound and 'funness' is like nothing else, i love mine!
Posted on: 2012/7/11 11:56
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Better are Dellorto DHLA or even Solex 40s.
Posted on: 2012/7/11 18:38
From Wagga Wagga
I am going to be running twin Dellorto DHLA.... wish I had a oval port head though.... not easy to get....
Posted on: 2012/7/12 4:47
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
Not easy to get? What happened to the one that came with your A15?
Posted on: 2012/7/12 5:24
oval port heads are easy enough to get, but finding an oval port head for a 'bargain' is a completely different story! Put a post up that you're looking for an oval port head, i would be surprised if you had no attention...
Also contact Bige member (Ernie) he build A series race motors, he should be able to help you out...
Posted on: 2012/7/12 10:57
1200 Ute - Mild A12
