INFO Needed on 1200 front Struts
I bought an old SCCA car and need help with the front struts. I measured the tube and its 45mm OD and 419mm long measured from the inside. It appears to be the stock 1200 strut tube, my question is what strut insert can I use. It didn't have an insert, just the piston with oil. Also any help with front spring rates and sway bar sizes would be greatly appreciated. Thanks
Posted on: 2012/7/9 21:33
Re: INFO Needed on 1200 front Struts
Ah, you have the good kind, you can put different weights of oil in it to get differing results.
see Struts for details
Posted on: 2012/7/9 22:33
Quite a regular
From Sacramento, CA
"Also any help with front spring rates and sway bar sizes would be greatly appreciated. Thanks"
The B-210 sway bar is a nice piece, and gives you 20mm, opposed to the 17mm stocker. Make sure that you use all the hardware off of the B-210. The stock spring rates are only about 90 lbs, so it isn't hard to overstiffen the front.
Tech Wiki section has lots of helpful info on sway bars, and spring rates.
-Craig
Posted on: 2012/7/10 0:12
Retired, But Not Tired
Since it was already a race car it has huge sway bars, 1" front and 7/8" rear. Just thought they might be a bit too big? I was hoping to find an insert, because I wanted to use gas charged units. They stay with you for the whole race. All help is appreciated.
Posted on: 2012/7/10 20:00
New: Nissan. Not sure if they still sell the gas version or not.
New old stock: Koni or KYB
VW Jetta inserts are a favorite to use in the stock 1200 struts.
Click Strut Insert Part Numbers for more information.
Posted on: 2012/7/10 22:45
From Narellan,Sydney
I used Pedders part no 8718 but I have shortened struts they may fit your set up but.not sure what there from just have my tubes to my mate that owns Pedders an he hooked me up
Posted on: 2012/7/11 3:34
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
If your in USA, classic garage stock wet koni kits for the 1200 struts,like yours. I got nos koni inserts for 260z. I'm more than happy.
Different oil weight is how to change the shock rates. 1200rc used 20_50 engine oil to stiffen his up years ago.
Posted on: 2012/7/11 5:14
I decided to go the VW Jetta strut. Ordered them this morning. Guess I will be making a retaining nut next week. Thanks for all the help on the struts, now if I could just find out about the spring rates.
Posted on: 2012/7/12 1:56
What matters most about sway bars is the front/rear balance. The ones you have might work well.
For the street, I prefer soft springs and stiff sway bars. The stock 1200 springs are 96 lb/in.
But others prefer stiff springs and more body roll.
Posted on: 2012/7/12 3:14
I found 175lb good on road in a 1200 with a series. Once L series 225 would be good but I got 250lb for great price. good on track but stiff on road all day
Posted on: 2012/7/12 3:20
