WTD 1200 ute strut brace + adj. camber tops
Just putting the feelers out for a strut brace for my ute, its not a track car but wouldnt mind one, let me know what you guys have!
Also if anyone has a set of adjustable camper tops laying around to fit the standard struts?? that're cheap, yes cheap (if possible anyway lol)
Cheers
Eddy
Posted on: 2012/7/13 12:08
Re: WTD 1200 ute strut brace + adj. camber tops
get camber tops from Jap importers 2ND hand or off Yahoo Japan and an importer such as import monster.
s13 ones work.
Strut brace, you might struggle cheap. Diy?
Posted on: 2012/7/13 12:33
just had a look at the s13 ones, they look good. Is this what a lot of people are using?
The strut brace wouldnt expect to be cheap, just seeing if anyone had one for sale, otherwise ill probably look at buying a mad dat one! They do look nice.
Posted on: 2012/7/14 2:30
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
IM using s13 ones, so are a few members. can't remember if the shock mounts straight up to stock 1200 struts. Needed spacers with.stanza stuff
Posted on: 2012/7/14 2:51
Message DISCO_BOB regarding strut brace.
Posted on: 2012/7/16 3:54
From Perth WA AUS
If you can cut and weld metal then a "supercheap" S13 strut brace can be modded to fit the B110, its easy and cheap. Cost me $20-$40 all up I think but they were on special at the time.
Posted on: 2012/7/16 9:18
Datsun 1200 2Dr sedan.
Does DISCO_BOB make strut braces?\
I will look into some S13's, hopefully some wreckers will have some sheels lying around but we'll see.
Posted on: 2012/7/16 10:43
1200 Ute - Mild A12
Yes he does make them. I'll PM you his email....hes not on here often
Posted on: 2012/7/16 10:47
From A-TOWN
Posted on: 2012/7/16 11:49
Nice Camber tops.
Posted on: 2012/7/16 12:11
