a14, a15 head in an a12?
From Adelaide South Australia
Hey i was just wondering if i could put an a14, or a15 into a stock a12, if so what would i need to modify for it to work properly, i also want to put this carby on it and i don't know what its called if people could help me with that also.
http://i1240.photobucket.com/albums/g ... eMexican69er/IMG_0265.jpg
http://i1240.photobucket.com/albums/g ... eMexican69er/IMG_0266.jpg
http://i1240.photobucket.com/albums/g ... eMexican69er/IMG_0268.jpg
The Japan 220 is prob where and the number of when it came of the line, but its there anyway.
Cheers
Posted on: 2012/7/24 10:52
Re: a14, a15 head in an a12?
From Perth
Aren't they L series carbs ?
In which case you need a new manifold anyway
So find that first... then worry about the head
Posted on: 2012/7/24 11:03
oh i thought they were for an A series oval port? what are they called do you know?
Posted on: 2012/7/24 11:06
looks like twin SU's off of an L series engine.
Posted on: 2012/7/24 11:16
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
is it possible to get an Aseries manifold for it and then put it onto an a12? or would that just flood it?
Posted on: 2012/7/24 11:19
Applied Model Code 220 is Datsun 510 SSS (L16 engine)
Yes, those carburetors will bolt to an A12GX manifold. But then you need a GX cylinder head, as the manifold ports are larger than A14 or A15 ports.
The SSS carburetors are the same as GX carburetors, only the needle jet and dome spring differ. The SSS is slightly leaner than the GX.
Posted on: 2012/7/24 19:05
You can do it however is it really worth it to you? Like are you just doing this because u have the carbs and you'd like them on your daily? If so by the time you buy either an h89 high comp head or a GX head your prob looking at 750 dollars plus wither way u go... Maybe a little cheaper for the h89 head. And forthe manifold as far as I know they're pretty rare here in aus. If you really wanted to put them on, I'd sellthe su's and buy the other ones straight off of eBay for I think 600 buy now IF they're still on there....
Posted on: 2012/7/24 23:52
1200 Ute - Mild A12
The H89 head has smaller ports than a GX manifold.
You can buy an aftermarket A12 twin-weber manifold. They sell new in Australia with round ports, so you can use the original cylinder head.. Just slap it on and tune the carbies.
Posted on: 2012/7/25 0:28
Those carburetors are Hitachi sidedraughts, and are a licensed version of the british S.U. (Skinner's Union) carburettors, though the Hitachis are different in various ways.
The ones in this photo appear to be Hitachi HJL38 models. 38 mm throttle bores (1.5 inch). They were used in Japan and UK markets, also South Africa and other places.
Posted on: 2012/7/25 0:54
wow, thanks for all the help guys, it doesn't really seem worth it now Cheers for all the help
Posted on: 2012/7/25 3:05
