A14 / A15 crank I.D.
From Sydney , NSW
Hey guys,
another question for the dattomasters out there. What identification marks are there on A14 / A15 cranks to tell them apart. I have a crank that I thought was an A14 but may be an A15. Rather than set it up in a block and do a lot of measuring I thought there might be a casting identification or something?? Any help will be greatly appreciated. Cheers
Posted on: 2004/4/6 6:36
Re: A14 / A15 crank I.D.
From Millgrove Vic OZ
Centre of crank pin will be 41mm offset from the crank centre line.
It is easy to do a guess/timate with a ruler. It will be either 41mm offset (A15) or 38.5mm (A14).
Posted on: 2004/4/6 11:30
Cheers Feral
From Sydney , NSW
Thanks feral !! Will now measure up and tag the bugger! Know of any A series 5 speeds about ? Have you had any issues with A series flywheels and their bolts? Have just upgraded mine to 7/16 UNF twelve point shouldered bolts to ensure the flywheel is located AND clamped (will also cut back on over revs!) Thanks for your help.
Cheers
Posted on: 2004/4/6 22:58
