Electrical Issues
Quite a regular
If anyone would be able to help,
I have suddenly found that the charge light on the dash has come on and is staying on regardless of rpm. Yesterday the charge light began to come on occasionally while at the same time the tacho started to bounce and also stop working. Although today the tacho is working again, the charge light is staying on even though I haven't touched any wiring also when I turn the headlights on the headunit will turn off for a second and work again. Previously my headunit went it to protection mode which is caused by a speaker wire short which I have fixed if this has any connection to the issue?
At the moment I think that it is a wiring issue as I bought the car about 2 months ago and it had a new alternator installed before i got it and has been running fine although occasionally in the morning when it was cold the tacho would bounce around a bit until warm. The guy I bought it off said that he installed the tacho dash so would a wiring fault be causing the charge light to come on?
I will still test the alternator when I get my multimetre though
Any help would be great!
Posted on: 2012/8/8 6:24
Re: Electrical Issues
Quite a regular
Also just reading through the wiki, if the regulator is broken would this effect the tacho?
Posted on: 2012/8/8 6:25
The instrument panel voltage regulator only affects the temperature gauge and fuel gauge. Nothing else.
Posted on: 2012/8/8 6:27
Sounds like you have some slightly corroded connections. The tacho will bounce if the connections are not clean metal.
Easy enough to test. Ignore the other intermittent problems and concentrate on this steady problem. Turn key ON engine OFF and check for 12V at the alternator T-connection.
Posted on: 2012/8/8 6:30
Quite a regular
Looked through the receipt and I got it wrong he replaced the starter not the alternator.
Just checked with a multimeter and there is no change from the motor on or off so must be a shot alternator. Sorry for making a new thread thought there was a connection with all the other things!
Anyone got a spare alternator??
Posted on: 2012/8/8 7:45
WAIT - no output at the alternator does not mean the alternator is bad. Test it. Do you get 12V at the T-connector? If not, that's a different problem. Could be as simple as the Regulator fuse needs replacement.
Posted on: 2012/8/8 8:19
Quite a regular
Oh right, sorry bit confused but do you mean put the voltmeter on the A and E on the alternator? If thats the case then yes I still get 12V
Posted on: 2012/8/8 8:50
Quite a regular
Also its an 84 model so it is internally regulated
Posted on: 2012/8/8 8:53
A & E?
Pull the T-connector out of the alternator. Check for 12V in the two wires that attach to the connector.
See Alternator diagnoses for a boatload of tests. Or just replace the alternator, and if it's not that, then buy a new regulator and if that doesn't fix it, take it to a sparky.
Quite a regular
Sorry A and E is where to 2 wires connect. Even when I pulled the T connector out of the alternator I still got 12V so does this mean that it is not the alternator but a fuse?
Or as the alternator is internally regulated, if that's faulty I'll have to get the alternator repaired hey?
Posted on: 2012/8/8 9:04
