« 1 (2)
Re: fairly easy to locate head. which one
Found a few h89 heads at local wrecking yard (pick a part).Can these heads be ported to gx specs? If so which intake manifold gasket do I use.Do they have the largest valves? Can I use the stock intake with down draft 32/36 weber or will I have to swicth to side draft? Are there any advantages of running points distributer with pertronix instead of original electronic dist. with black box? Any input well appreciated.
Posted on: 2012/9/6 4:02
From Malaysia
iirc h89 have the biggest stock valve. 32/36 is a good bang for buck carb. you don't have to switch to sideys. use stock intake manifold gasket for A15.
Posted on: 2012/9/6 5:19
« 1 (2)
