trouble with my holley
From Lismore NSW, AUS
hey guys I'm having some trouble with my 180 holley on my 1200 ute it's very unpredictable but every now and then it just dies off and runs rough as sh** it will rev when i first give it a squirt but if i hold the throttle on it just dies off it is an old carbie but i have put new seat needle gaskets etc and it was running fine up untill a few weeks ago i have had it off and cleaned it out and everything in there seems to be fine does this sound like it could be water in the fuel as someone told me this is what it could be if so does anyone know how to check for this and if i can solve the problem without draining the tank, Cheers, Nathan
Posted on: 2004/4/10 23:40
Re: trouble with my holley
Try replacing your fuel filter. It's cheap, easy enough to do, & you probably should heve done it at the last service.
As the filter becomes blocked over time, or with some water, it allows less & less fuel through. This can degenerate to the point where there is enough fuel flow to maintain light throttle work, but once you give it the suds, the flow through the carb jets is more than the filter can supply.
Result? The carb runs out of fuel. You then close the throttle & roll to the side of the road. Meanwhile, the reduced flow to the carb fills up the bowl again & the engine runs.
Change the filter first & see if that fixes it.
Posted on: 2004/4/11 2:13
Love your Datsun.
Treat it well.
From Melbourne, Australia
if you suspect water in the tank im pretty sure the solution is to add like a litre of methalayted spirits
can someone confirm this one?
Posted on: 2004/4/11 4:08
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
The metho is supposed to be good, but if the water has reached the filter, it's gurked.
Posted on: 2004/4/11 8:56
Love your Datsun.
Treat it well.
thanks for the info guys I'm always appreciative of the wealth of knoledge I can find here my ute has a new fuel filter and as the problem only happens sometimes and then it will run fine for a while i think it may be something else, i will try the metho and see how it goes ...... will be in contact...
Posted on: 2004/4/12 10:38
