early vs late model mechanical fuel pumps
My fuel pump seems to be pissing out oil everywhere, the only place i can spot where its coming from is what looks like the two balls at either side (on the outside) connecting the arm that sits on cam shaft.
I have pulled it apart, all looks good. Except the balls, they look to be sitting a little more inward than another pump i have.
What i want to know is if i try putting the other fuel pump onto my late model a12 block and if its and early model fuel pump, am i going to damage anything?
All help welcome, need to get this sorted asap!
Cheers
Ed
Posted on: 2012/10/5 4:43
Re: early vs late model mechanical fuel pumps
From Melbourne, Australia
yeah probably, later ones have a shorter arm, if you put the early one in it's likely to break the arm and then you will have to go searching for it in the bottom of your sump
Posted on: 2012/10/5 5:36
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
#OOPS#, i have matched the two pumps up and they seem to have the same length arm. I have an a14 sitting their with a pump on it but that has the spacer... The one im running on the late a12 block atm doesnt use a spacer. Im confused :S haha
Posted on: 2012/10/5 5:46
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
You wouldnt happen to have a spare for sale RC?
Posted on: 2012/10/5 5:47
1200 Ute - Mild A12
think i chewed through all my spares for late model
can buy em new from auto shop, i think they arnt too expensive
Posted on: 2012/10/5 6:34
1200 Coupe Rallycar
no worries, pulled one off the a14, seems to work. at least fuel spurted everywhere haha. I suppose thats a good sign.
What auto shop??
Posted on: 2012/10/5 6:40
1200 Ute - Mild A12
any... bursons or autobarn etc
Posted on: 2012/10/5 6:41
1200 Coupe Rallycar
From Melbourne AUS
i once made 1 pump that'd work out of 2 that i had, swapping the longer arm for the shorter or vise versa
it was a while ago so i cant remember exactly what i did but i do know thats is possible,
not sure if that helps you at all though
Posted on: 2012/10/5 7:45
1973 B110 A12
Thanks RC.
Yeah ANGE i had a rough look and a thought of doing that. I cant fiqure out how to remove the leaver/tongue itself but you can just unscrew the bottom and swap it over.
I needed to pull the leaver off and swap it with other because it was the little balls at either end connecting the leaver that were pissing oil out of.
Either way found another pump and she's all going again, just have to hope this one doesnt leak oil!!
Posted on: 2012/10/5 7:56
1200 Ute - Mild A12
