1200 brake HELP!
From Ohio, USA
Hello, I need some insight/help with getting my rear brakes on my 1971 1200 coupe set up right. It has an H150 from a b210 (b210 rear brakes), 280z 7/8 master cylinder and stock front discs. The problem is that the front and rear brakes aren't proportioned correctly. I have some brand new stock 1200 11/16 wheel cylinders that I was going to swap on to correct the bias, but when I went to swap them on I found that they are a completely different design and shape than the b210 13/16 wheel cylinders. They are not interchangeable. What can I do to fix this, is there any way to use the 11/16 wheel cylinders without swapping everything back to stock 1200? Should I install an adjustable proportioning valve? If so where?
Thanks,
Aaron Kraemer
Posted on: 2012/10/8 18:01
1971 Datsun 1200 Coupe - rebuilt A14, h150, 2.25 exhaust, slotted mags. e15t w A series 5 speed coming soon...
1973 Datsun 240z- L28, twin SUs, SM needels, 6-2 header, twice pipes, MSD 6a, e12-80, 6000k hid, 82 280zx close-ratio 5 speed...
Re: 1200 brake HELP!
If you change the size of the front brakes or the size of the rear calipers it changes the proportioning. B110 brake proportioning is front small calipers with rear 11/16 cylinders.
As you know, changing the size of the master cylinder does not affect the proportioning at all.
With the 13/16s, I don't recall any report of problems with brake action (a lot of guys do this). Is it not working right? If the rear brakes lock up too soon, it is bad. What you can do is:
1. swap the rear brakes (which means swapping the brake backing plates, so new axle bearings are needed)
2. Put the 1200 rear axle assembly back in and only swap the pumpkin (center section) to the H150. It fits in the 1200 housing. You do not need a spacer, just use three gaskets and torque to specification.
3. Use an adjustable proportioning valve. Most guys get them from old Volvos.
PERHAPS the proportioning valve from a Datsun 210 will make it work acceptably. It was used with 13/16 rears and 12" or 13" fronts. So it should work on a 1200 with 13/16 rears.
Posted on: 2012/10/8 21:29
