« 1 ... 24 25 26 (27) 28 29 30 ... 49 »
Re: Datsun 1200 sedan project..
From Trinidad and tobago
custom Cowl vents.
Posted on: 2012/10/12 21:26
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Update.
Bodywork continued today.
Happy with the outcome.
Among the other cars.
In the paint room.Loving it.
New Paint aplied
Posted on: 2012/10/13 2:48
Street Sleeper!
Looks great the paint came out really well!
Love the custom cowls, wish i could get some over here in aus!!
Love your attention to cleanliness with the box too!
Posted on: 2012/10/13 6:29
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Thanks mate.I will get some HD pics soon.The custom cowl vents will look tops when i install them.
Today i replaced my original 17mm sway bar with a 20mm one. In for a test drive tomorrow.
Jacked up the car to remove 'old' swaybar.
Now bar fitted.
More updates to come.
Posted on: 2012/10/14 3:28
Street Sleeper!
Went for a drive in the 1200 and that new swaybar has improved the handeling ..I'm comfortable with the swap.Now its time to lower the front.
Posted on: 2012/10/14 23:57
Street Sleeper!
Update.
Bonnet painted on my datty.Here are some Pics of the Car.
Water stains from sitting out in the rain for a week,A good buff and its all good
Only Vintage in the arena.
Plan to put Bonnet pin for saftey ,How does it look to you all ??
Posted on: 2012/10/20 2:46
Street Sleeper!
Did you block off the original cowel vents? And those custom ones will just sit on top of the cowel panel??
New paint looks good, good job!
Posted on: 2012/10/20 3:49
Yes I did Block off the cowl vents.I had some issues taking out the vents and some were broken up,So i blocked up the cowl panel.
I Also installed some teflon bushings.
Well Over the weekend i installed my new radiator,had to make some minor adjustments to the bolting up.I used 10 bolts and pass them true the 12 nuts that are on the radiator.Works very well and i ran it on the hiway and the temperature did not pass 1/4. Here are some pics.
Had to take out the grille to work.
New Radiator.
Posted on: 2012/10/23 3:54
Street Sleeper!
Nice big radiator. Does fan hit the inlet when engine Rocks? Looks tight
Posted on: 2012/10/23 4:06
Yea It has a fair bit of clearence
Hood resprayed
Since ive got my hood pins put on and adjusted
After I washed the car and carried it home
Cheers:Darren
Posted on: 2012/10/26 1:52
Street Sleeper!
