Browsing this Thread:
1 Anonymous Users
Datsun 1200 sedan rear wheel seal |
Can somebody tell me what is the measurments for the rear wheel seal on my 1200 sedan? The rear brakes doesn't take that well when thers a little oli leak in the seal:P
Posted on: 2012/10/30 17:26
Re: Datsun 1200 sedan rear wheel seal |
Registered Users Contentmaster Usermaster
Rear wheel cylinder? Or rear axle seal?
Posted on: 2012/10/30 17:53
Axel seal
Posted on: 2012/10/30 18:51
Do not know the measurements, but here's the part number:
Nissan 43252-H1000 SEAL-OIL REAR AXLE SHAFT
It fits many Nissan/Datsun including: * 1200 sedan/coupe/wagon/truck * Datsun B10 Datsun 1000 * Datsun 510/610 * Datsun A10 1978-1981 (Stanza/510/Violet) * Nissan D21,D21U,D22 Nissan pickups 1986-2000 some * Nissan R50 "Pathfinder" * Nissan WD21,WD22 "Pathfinder" * Nissan/Datsun 810/910 wagon (810/Maxima/Bluebird)
Do not forget to repack the rear axle bearing. A leaking seal allows gear lube to wash the grease away.
Posted on: 2012/10/31 0:29
Here are the measurements * For 41.00 mm Shaft * Housing bore: 56.00 * Seal O.D.: 56.25 * Seal width: 7.00 * Lip material: Nitrile (NBR)
Used by Honda, General Motors and others. Hub seal, axle seal, cam seal, or crankshaft seal.
Posted on: 2012/10/31 2:09
Got it fixed today so thanks alot.
Posted on: 2012/11/1 18:24
